APX HELP
JMR3865
Monmouth County, NJ
Hi All,
A couple questions on the APX series. I'm looking to use it more as a receiver.
Can the APX
Monitor a phase 2 talkgroup/trunked system without being on the system
Scan multiple trunked systems
Scan trunked systems and conventional channels?
Thanks for the info!
Mr_Boh
The Land of Pleasant Living
Yes on all. The last one there are some caveats about conventional and trunked at the same time. I haven’t done too much since I typically just scan multiple trunked systems but for trunked and conventional I think the Scan Lists can’t be blended but you can scan a Conventional list while parked on a talkgroup and scan talkgroup list while on conventional like the Astro 25 series stuff. I’m sure someone will correct me though.
JMR3865
Monmouth County, NJ
How does one program the radio so thatf it will not try and affiliate with the trunked system
Sent from my SM-G950U using Tapatalk
parma,ohio
You just Open a can or WORMS on asking how to program it like a scanner PAY someone to do it for you who KNOWS how do it. Don't try it by your self or your radio will get bricked.
JMR3865
Monmouth County, NJ
I'm not new to programming. I have been programming for over 15 years, however, I have never programmed a trunking radio nor the APX's.
I was simply asking if there was a way. If someone could explain how, that would be superb! I am not against someone else programming it to ensure that it is done correctly.
Mr_Boh
I’m going to sound a bit nasty saying this but I’ll say it anyway - it’s well documented here and other sources. No need to start yet another thread on it.
Phase II just adds another minor layer to the programming. If you can follow the steps for a Phase I system and understand what each setting means and why it’s set the way it is, you should have no problem doing a Phase II.
KE4ZNR
Radio Geek
The problem is to properly program an APX radio to "No Affiliate Monitor" requires
one to create a bogus System Key which can be (depending on local laws) illegal or or at the very least frowned upon. It is akin to creating a key for a house door lock for a house you don't own and have not been given permission to enter.
Marshall KE4ZNR
N4KVE
PALM BEACH, FLORIDA
Except to create a house key for a house you do not own, you would have to steal the original house key, & take it to Home Depot, or anyplace that has a key machine, copy it, & return the original key. With the radio, you simply go on the computer to a key generating site, & generate a key without stealing anything.
KE4ZNR
Radio Geek
Except that in some areas generating a key is either illegal and/or frowned upon by those responsible for maintaining said radio system. That is kind of the whole purpose of System Keys: to keep those that should not have access to the system from the system. Granted, Motorola has giant flaws in how this is implemented but that still does not make generating a system key without the system administrators permission ok.
Marshall KE4ZNR
N4KVE
PALM BEACH, FLORIDA
but that still does not make generating a system key without the system administrators permission OK
In life, there are many choices, & many shades of gray. In my life, there is only 1 question I ask whenever I do something. "Will I go to jail if I do this"? If the answer is yes, then I don't do it. It's not like going to a key generating site will have the same consequences as going to a kiddy porn site.
kingpin
Trailer Park Supervisor
Seattle, WA
Bricked
And I don't mind telling you as a system administrator, I will brick your radio if it doesn't belong on my system . Been there, done that. Someone has some expensive paperweights.
Stay off of systems where you don't belong, and you won't have trouble.
allend
Long Beach, CA
Depot Software will fix this problem
JMR3865
Monmouth County, NJ
Just to clarify...
I am a FF/EMT. I have permission to use our VHF system. I MAY have the ability to use our trunked system that is coming our way. I am NOT looking to transmit on anything that I shouldn't be. I just want to listen to the trunked system with a radio, not a scanner.
parma,ohio
sure don't think the system administrator can care less what and who you are lol have someone who KNOWS how to program the radio or have the police at your front door.
radioman2001
New York North Carolina and all points in between
I think the best response is "If you don't know how to make your radio do NAS, then don't do it". There are plenty of sites out there for information, and this one doesn't like said information posted here. At most of the others they will not program your radio or hand hold you, so do some research, and learn.
N4KVE
PALM BEACH, FLORIDA
Just to clarify...
Then have the person who gave you permission program your radio.
kingpin
Seattle, WA
True, but you shouldn't have it unless you are authorized.
Forcing a radio onto a public safety trunked system you are not authorized for, is asking for trouble. It is a felony in the state of Alabama for example. It's not worth it.
