APX High Speed Data
smrdwnnow
OH
I am a sys admin on a Moto 7.19 system and we just purchased the flash update to enable High Speed Data(HSD) before the keys get here, i was looking to start prepping our cpg's but i am unsure what settings i need to configure to enable HSD. I am aware they may not be visable in the non-flashed version of the cpg i am just curious where i will look when the keys do arrive and I start to re-tool our cpg's. any help would be appreciated!
Mr_Boh
The Land of Pleasant Living
Do you mean HPD (or Enhanced Data)? Most of the changes you would want to make fall under the data profile, which you then assign to the Trunking System. HIGHLY, HIGHLY, recommend working with your MSI ST, or whoever is deploying the data to make sure everything is set up properly. There is little to worry about on the Codeplug side though, it's really not a time consuming endeavor like manually maintaining a UCL.
KevinC
The big K
Super Moderator
Home
I was thinking he was referring to the tethering to a LTE modem via WiFI, but I've never actually encountered that before.
Mr_Boh
Could be since although it's been "kicking around" for a while, you need to be 7.18+ and he said he is 7.19. Never really tested it in full myself, but it has been implied to me that anything that can leverage IV&D (or Enhanced Data or HPD for that matter) can be routed through modem tethering. If you are getting into that, programming would be a little more time consuming depending on what features are being used (AMS, ARL, OTAP, OTAR, etc) since you would have to have intimate knowledge of the network design and topology between IV&D, your mobile broadband, and the various components whether it be IMW, KMF, RM Server, etc. Point being you would have to make sure the packets can make it from whatever is hosting the service and the subscribers. Again, this is why leaning on the STs (or appropriate channel partner contacts if that is the route they are using) is important.
ResQguy
Meh
Definitely reach out to your CSM and STs. This is a highly technical topic, and since Motorola never released a "7.19" system I suspect perhaps some more research is in order. 7.18 was the last of the 7.x system names for Astro25- maybe you are a 2019.1? You're going to need to make sure you have that feature enabled on your system and configure the records in PM before you start altering subscriber codeplugs.
