APX mdc muting
Baker845
Oregon
I was wondering what best settings are for MDC-1200 muting on APX-6000? On XTS-5000's radio i have in the past the MDC-1200 worked nicely. APX mdc-1200 the muting sounds off and can't seem find any info on what best settings is for APX MDC-1200.
KK6ZTE
California
What is your Rx Unmute Delay set to under Conventional Personality?
KK6ZTE
California
Our radios are set to around 500ms. Try that and see if it helps.
Baker845
Oregon
Changed it to 500ms, there little bit of change. still it and miss on muting.
KK6ZTE
California
It's only going to affect BOT bursts, it won't stop end of transmission. Also won't stop bursts if the system in use has excessive hangtime and doesn't drop out in between transmissions.
Baker845
Oregon
understand, i do notice my radio mutes correctly off and on, so i can live with that. Thank you for info and help..
ElevatorsAndRadios
yarewesog
SoCal
Is your issue that your radio fails to mute? Or do you miss the shortened MDC chirp that you got with your 5000? APX MDC muting sounds considerably different - there is almost no chirp at all. Remember, the point of MDC muting is to avoid hearing as much MDC as possible. APX radios have gotten better at this, so often times you will hear nothing more than a "blip" of MDC with EOT bursts. It's not a fault - just the radio doing what it was designed to do. XPR radios mute the chirp entirely.
Baker845
Oregon
I'm still new to APX radio line, so wasn't sure if i had the MDC settings correct. Yea the APX doesn't have mdc chirp like 5000. I do hear blip at EOT. I wasn't sure, but sounds like its working as it should.
