To anyone looking to acquire commercial radio programming software:
Kinda losing my mind on what else could be wrong on this. Got my trunking profiles set up. Using nas with hidden trunkgroups. I can occasionally pick up transmission but not everything, comparing to a G5 thats grabbing everything. Any ideas?
because the G5 is designed to be a scanner. When using an APX as a scanner your asking the radio to do things it is not designed to do. I had two identical Motrorola radios set up for NAS scanning the same 10 talkgroups, there were times one would get the transmission and the other wouldnt. NAS is tricking the radio to scan Talkgroups from an analog scan list.... also C4FM vs CPQSK Is it simulcast? lots of varibles
Not accurate. The APX is using a Multi-System Talkgroup or Intelligent Priority type scan list, not "an analog scan list". Those scan list types were explicitly designed to scan between conventional channels and trunked talkgroups. The fact that the radio sits on a conventional channel while in non-affiliate scan mode doesn't mean anything, it could just as well be sitting on a talkgroup using the same scan list types.
I was thinking the conventional was grabbing and monitoring for whatever reason, even though its a random non-used frequency and a random PL assigned.
I'll give the system search time a try. Thanks again for your help!
Interesting. I suppose I've never had that issue since my NAS conventional channels are set to astro and unmute rules only apply to PL. All my nas scan lists are trunked talkgroups
That really fixed it? Are you scanning any conventional channels or the scan list is all trunking talkgroups? If the system search time is set to the default of 2-3 that would somewhat explain why. If you only scan one system per scan list a system search time of 255 would be appropriate
If you notice it still slightly off or clipping, I have a few other suggestions I've come across in NAS experimentation that cause missing transmissions
My APX 6000XE and 8000HXE never miss anything actually my G4 and SDS miss stuff all the time. NAS is tricky you have to know what your doing one little thing checked or unchecked or entered wrong can make a world of difference.
My APX7000XE Luxury Transceiver is the finest piece of equipment available for monitoring my local P25 trunked system! Never misses a call and it's always with me, wherever I go whether that be at the tennis club, yacht club, a drive along the coast in one of my Ferraris, or participating in rescue drill operations will the local sheriff's office, with whom I am closely affiliated.
My APX7000XE Luxury Transceiver is the finest piece of equipment available for monitoring my local P25 trunked system! Never misses a call and it's always with me, wherever I go whether that be at the tennis club, yacht club, a drive along the cost in one of my Ferraris, or participating in rescue drill operations will the local sheriff's office, with whom I am closely affiliated.
