APX PORTABLES
willwilliams
Coalhurst
i have a question for the group. we have a bunch of apx6000xe and 7000xe radios programmed on the AFRRCS system in Alberta. can anyone tell me how to stop the radio from beeping everytime it switches sites? i can seem to find anything in the cps that prevents this.
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
Never had it happen here with my APX7500 mobile, nor heard it on the handhelds at work (not sure if they're 6000s or 7000s). Just a stab in the dark - wonder if it's something like System Registration Indicator in Radio Ergo > Display ? Maybe every time the radio affiliates/registers it's alerting you to that fact.
Thunderknight
Bletchley Park
Have you tried turning off each of the 4 items in Ergo | Display (OOR, imbalanced, Site Trunking and System Reg)? Maybe it's detecting one of those other states while switching sites.
hitechRadio
Can you explain the beep, is a short beep, several beeps a low bonk?
I am curious, being the technician I WANT my radio to do this when switching sites, for testing reasons!!! LOL
I am running the latest FW 15.12.00
willwilliams
Coalhurst
I have it all turned off including the priority beep and still dose it. We have 4 sites and this just keeps beeping all day long.
Jay911
Some more blind stabbing:
- Any of the sites in Site Trunking?
- Does it do it regardless of which channel/TG you are on?
- Do you have Full Spectrum CC Scan (I think that's what it's called) enabled?
- System type? Inter-WACN or Intra-WACN roaming, or something else?
- Any obvious differences between your mobile codeplug and handheld codeplug?
- What firmware, flashcode are you running?
mikewazowski
Staff member
Forums Manager
Oot and Aboot
My guess would either be GPS Fail Tone or one of the Trunking Tones under Display/General such as OOR or Imbalanced Coverage.
hitechRadio
How do you know for sure the beep occurs only when it switches sites?
I believe you said you did but.....Did you turn off Out of Range?
Compare your Mobile code plug to these 2 menu items.
Better yet compare both CP's side by side.
Be sure to change view to expert view.
These two I am curious about......
Under trunking wide compare those settings. Specifically Filter constants and below. (Problems can occur when these are messed with.)
Under trunking personality and preferred sites.... compare them.
Even if all this as you stated you have turned off all the Ergo tones, I see no reason or setting that would cause a beep when switching sites.
Which makes me think it is not related to switching sites at all, but I have seen stranger things in my day.
willwilliams
Coalhurst
When i compare them both other then the mobile vs portable stuff i don't see a difference on anything. we have updated to the latest firmware. I'm sure its site switching because i have been checking right after it dose the beep and we have changed sites. it dose not matter what talk group. Not as bad in Lethbridge but as I've drivin around Calgary its was real annoying. i'll call the folks at Motorola tomorrow and see what they come up with.
riveter
MD
Do they show the IP icon for an active IP-data connection? (ARS or GPS data typically)
If they do, that beep may be loss of IP link upon roaming. Mine beeps if the system drops or incorrectly/slowly roams the IP link, and it takes a minute to re-establish.
willwilliams
Coalhurst
well that did it. thanks
