APX radio question
Baker845
anywhere
I have question about APX 7000 radio. I have a radio that has the Trunk Talkgroups when I click on one they don't highlight. where these locked out and is there a away to unlock them?
thanks
thanks
Wow. So many questions.
1) Do you have a trunked system programmed into the radio?
2) Does the trunked system match the trunked personality?
3) Are any fields red?
4) Check your "invalid fields report".
5) Is your radio flashed to allow for the trunking system?
6) Where are you looking at your talkgroups? Under the trunking personality? (some have confused the trunking hot list as the talkgroup entry)
BE CAREFUL! I'm guessing you're trying the old "hidden talkgroup" method and if you make a wrong move, you'll end up validating with the system. Make sure you follow the instructions to an absolutely T.
Baker845
anywhere
There is a TRS system programmed in the radio .Looking in that area, it says False. the system key isn't Present.
GTR8000
NY/NJ Database Guy
BEE00
Then you don't have the correct system key(s) loaded, which is why you are unable to make changes.
