APX/XPR antenna compatibility?
jruta
Nj
Hi all. Anyone know if XPR antennas are compatible with APX? (Specifically PMAD4068c) looking for a VHF-only antenna for my APX6k for the 155mhz range. I can’t seem to find anything specific to the APX in vhf that’s not the wide band.
Thanks in advance
John
MTS2000des
5B2_BEE00 Czar
They are compatible except you may have to remove the rubber O-ring wrapped around the SMA on the antenna to get the antenna to fully seat on the APX. I've had no issue with these on VHF APX radios.
jruta
Nj
Thank you for the quick response. Does the o-ring come out easily? Does it need to be cut out? Thanks again
