APX
ChrisJones12
Newbie here
I’ve got VP600 and just got an APX6000. I have figured out the conventional programming, but is it possible to do a non affiliated scan of any of the MOSWIN system?
In mid mo
Chris Jones
K2NEC
5F6
Any of the VP series require a system key from EFJ, so thats a hard no for the VP600
ChrisJones12
Sure is. Is it encouraged? No. You’re much better off using a scanner. Scanners do no affect trunking systems. Programming an APX to a trunking system can risk affiliation. And you don’t want that.
So it’s not possible to just listen non affiliated?
clbsquared
Isle of Wight County
It can be done. And it has been documented and beaten to death in these forums. So much so that it has been pinned to the top of the Motorola forum.
You’re going to have to do your own research on how to do NAS. There’s a ton of info on it all over the internet. However, be warned, if you have no experience programming trunking systems, you really shouldn’t attempt something that could have legal/criminal ramifications.
ChrisJones12
i currently do nor, so i guess i'll just stick to the conventional and ask some pros about getting moswin stuff progarmmed
ChrisJones12
Hmm okay, now I’ll just have to get this APX programmed with all of my fire department stuff. It’s much different than programming. Anything with unication or Kenwood
