apx1000 vs 4000
davidgcet
i'm no longer with a batwings shop so i'm out of the loop a little on the APX line. is the 1000 capable of doing both analog smartnet 3600 AND 9600 p25 phase 2 at the same time without having to be reprogrammed? i know the 4000 and above can have both system types installed and usable, but last i had heard the 1000 could only be programmed for one or the other so to change systems you had to reprogram the radio. is this still the case?
Mr_Boh
The Land of Pleasant Living
As it is sold by Motorola, it's either or 3600 or 9600 baud. They are trying to specifically tier the pricing with all of them. For example, if you need more than AES for algos, you have to jump to a 6000R or 8000 even if you only need one band.
Again.. that's how they are sold *cough* *cough*.
