APX1500 powering up in emergency
mancow
N.E. Kansas
I'm trying to program an APX1500 (legitimately) but overlooking something that is causing it to power up and try to send an emergency indication. I'm looking all over but not seeing what the heck it is. Any ideas where to look in the codeplug? The last one fired up fine. We are not using any DEKs or any other outboard accessories. There is nothing on the 26 pin connector.
RFI-EMI-GUY
On the spectra radios the emergency alarm pins are normally closed, so require a jumper in place at the accessory plug to defeat it.
Sent from my SM-T350 using Tapatalk
mancow
N.E. Kansas
Yep but this one is really confusing me because we have another that powers up fine with no accessories either and it doesn't do it. I was hoping to avoid having to comb through the programming of each looking for the discrepancy.
RFI-EMI-GUY
The installation manual specifically requires a jumper from one pin to ground on the 26 pin connector, and describes exactly your problem if you do not. Try that first, then compare emergency options and VIP programming with the other radio once it boots up.
