APX2000 Knob
P25andstuff
I have one question that I can't find the answer to anywhere even in the CPS (Unless its very well hidden). The volume to my radio is stuck at 6 no matter how much I turn the knob it stays on 6, I even made the conventional personalities to "Loud Audio." What am I missing here and how can I get the volume knob to work?
Im also having the same issue with my channel Knob, I can only go 2 channels at the time with the knob, and I have to go to the keypad to change channels anymore than two. How can I fix this?
Ant9270
The Green Weenie
What is your maximum audio volume set to under the selected audio profile? Default is 255.
Ant9270
The Green Weenie
You can call me stupid, but I can't find Audio profile.
It’s under radio ergonomics. Make sure you’re working on the profile you’ve enabled under each personality. As for the channel issue, did you enter the personalities you programmed into a zone?
P25andstuff
Yes I did put the conventional personalties I made into a zone, Ok I'll check and make sure im working under the profile as well.
P25andstuff
Ok I think I figured out the audio problem.
Ant9270
The Green Weenie
I re wrote the radio, volume is still stuck on six
Did you try the above suggestion of checking the Audio Profile, and making sure that you're working on the audio profile youve selected under the specific personalities you're having issues on?
P25andstuff
When I read the radio it doesn't even give me the option to check the default even when I go into advanced mode.
Ant9270
The Green Weenie
You need to ensure that you're viewing the CPS in Expert mode. Once thats done, Go to Radio Ergonomics, Radio Profiles, And check to see what the maximum rx volume is set to on the profile enabled under said personalities you're having an issue with.
P25andstuff
Ok im in expert, and I see "Covert Profile, and thats set to default" and I see "Default profile, and thats set to Loud Audio."
Then when I go to a personality I don't even have the option to go profile enabled. It doesn't even show up, I went through one of my personalities very carefully.
P25andstuff
Audio profiles are set in channel assignment to zone.
Yes I found that and made everything max. Also my apx is running R9.00.01 and i've been told this isn't good firmware, so I probably need to upgrade that.
