APX6000 Battery level not showing
Locotuss
Chesterfield Mo
we have over 80 APX6000 with each person having two impress batteries. some will not show the battery level. They are placed in the charger, some over night so they are fully and correctly charged. Is anyone else having this issue. has anyone found a solution. Our radio technique shaking his head.
Arizona
When was the last IMPRESS cycle done on the batteries in question? You can force the charger to do a IMPRESS cycle by dropping the battery in the charger and with in a couple seconds remove the battery and put it back in. The yellow light display on the charge to indicate the IMPRESS cycle.
riveter
MD
I second that motion. I had that happen with my 7000's battery about 5 months after getting it. Turned out the charger didn't feel like conditioning it and I think the battery firmware got a little confused.
Condition the batteries and try it again. If that doesn't do it, see if you have a BATT menu item programmed in the radio or can program one, and try checking to see if the radio will read the battery data via that menu.
Arizona
Glad it worked. These batteries will loose the ability to display the battery gauge if they haven't had the IMPRESS cycle in a couple weeks. For the life of me I can't remember how long for sure. If these batteries you had the issue with are back up batteries and don't see the charger very often you might run into this again. However that doesn't mean they are dead, they just won't show how much life is remaining in them.
gtaman
TACSAT
GALAXY 19 91.0° W
Yup. Happens to me all the time. I leave a back up battery for 3 weeks and the gauge and battery info are gone. A drop in the charger and it's fixed.
