APX6000 BN
junior71
Just received a 6000 BN model and noticing low volume as bad as a AN model. Any tips to possibly fix the problem would be greatly appreciated.
GTR8000
NY/NJ Database Guy
BEE00
The only solution is to add QA09006 Adaptive Noise Suppression to the FLASHcode, which unlocks the additional wattage on the amplifier. Otherwise you're stuck with the same pitiful audio output as the AN models.
PS - If you have a 6000Li, QA09006 is not an available option; must be the full feature 6000/6000XE BN model.
junior71
I have a 6000XE BN. Thanks for the help, I’ll flash that option in.
I thought I read it already had a 1 watt output. I know the AN has a .5
mbnv992
AZ
Yep the BN with that flash should have a 1 watt speaker.
The 6000BN/8000 XE models, along with the 8000H/HXE all have a 3 watt ( 5 watt max audio ) speaker.
Not sure if it’s a different speaker in the 6000BN XE / 8000H models or just same speaker with a higher output.
junior71
Update Had the radio flashed with the adaptive noise suppression feature, all I can say wow what a difference in volume.
GTR8000
NY/NJ Database Guy
BEE00
Yup, huge difference. That feature is standard on the 8000, but optional with the 6000BN. Unfortunately it seems that many don't realize that feature unlocks the full output of the audio amp, so they don't order it.
junior71
I really appreciate your help with this matter. Thank you.
mbnv992
AZ
Speaking of speakers ( see what I did there )
All the Motorola specs pages say for a APX6000BN XE, APX8000XE, APX8000H and APX8000HXE all have a 3 watt speaker ( 5 watts max output )
Whereas just the standard apx8000 and apx6000BN have a 1 watt speaker.
Can anyone verify that ? Does the 3 watt / 5 watts max speaker sound that much better than the standard 1 watt speaker on the 6000BN / 8000 ?
