APX Apx6000 Issue
slobonmycob
Know-Nothingism
For some reason on my apx6000, it will randomly light up solid orange at the top and static will come out of the mic.
Whenever I’m scanning, if someone talks it will broadcast whatever audio is being transmitted and then go right back to static and solid orange light at the top??? There’s no message on the top display or main screen... the emergency button isn’t being pressed and I’ve tried trouble shooting the issue by turning the radio completely off, removing the battery and antenna, and rebooting multiple times but the issue persists.
Any help appreciated
Ant9270
The Green Weenie
Do you have monitor enabled on a soft key? Sounds like you've long-pressed a softkey set for monitor and now have it set on open squelch. Also, are the channels youre having this problem on programmed without a PL/DPL? (CSQ)
slobonmycob
Know-Nothingism
I’ll have to double check. I’ve tried holding the emergency button to rest emergency mode but that didn’t work either.
W0JJK
Does the screen say "out of range"? It usually only turned orange for that or low battery.
Ant9270
The Green Weenie
You really shouldn't be receiving static on a TRS. Sounds like this is an issue on the system side, not a subscriber issue. Steady orange light would indicate you're receiving a signal/traffic. Is an ID Showing on the screen when you hear said static noise? If so, it appears that someone has a stuck PTT. Since you indicated you're having this issue on a trunked system, You can write out the monitor soft key issue. It wouldn't have anything to do with Out of Range indication, as that would display as RED... Not Orange.
slobonmycob
Know-Nothingism
stand by I’ll send you a video. There’s no message or ID showing.
Ant9270
The Green Weenie
Assuming that you have a legitimate ID on the system, it may be best to just contact your System Administrator if none of the simple "Do it yourself" fixes work.
slobonmycob
Know-Nothingism
Judging by his past posts I'm pretty sure he doesn't have an ID on the AWIN system.
radio won’t affiliate and that doesn’t answer why it stops transmitting static to broadcast traffic.
nice strawman though
KevinC
Other
Super Moderator
Home
Your conventional channel is in CSQ. It is receiving something, so the orange RX light is coming on. Change it to some other frequency that has no signals on it.
K2NEC
It's in analog rx mode and it's receiving some sort of digital signal. It has no PL, therefore it hears everything on that channel.
What Kevin said should fix it.
RocketNJ
Pequannock, NJ
Take it out of scan. If the issue goes away then look at the scan list for conventional channels. Check programming on those!
