APX6500 Missing Transmissions
APX8000XE
Classified
Hello,
I have an APX6500 and when I am scanning, it takes almost 5 seconds for the radio to lock onto a channel, I also have another 6500 and I do not have this issue, is there something that needs to be changed in CPS? Any help is appreciated.
GTR8000
NY/NJ Database Guy
BEE00
You're going to need to be more specific before anyone can begin to help.
What type of scan list? Conventional? Priority Monitor? Multi-System Talkgroup? Intelligent Priority?
What is your Voice Rx Tx Hold time set to?
How many channels/talkgroups are being scanned?
If multi-system trunking scan, what is your System Search Time set to?
APX8000XE
Classified
It is a conventional scan list, Hold time is set to 3 seconds, I am scanning 30 channels, 24 analog, 6 P25 conventional.
Tech21
When was the last time the radio was tuned, had a firmware update or any type of basic PM?
Is your other 6500 set up the same way? When going from analog to p25 conventional, it's normal that it is going to take a little bit because the radio has to switch between systems. Try setting up 2 scan lists as a test. 1 for analog and 1 for p25 conventional and see if the issue remains.
APX8000XE
Classified
Yep, it's set up the same way.
Tech21
Take the codeplug from the one that works correctly and clone it to the one having the issue. If the problem stays, it's a tuning/firmware issue and not a programming issue.
APX8000XE
Classified
I can't clone it, they both have different flashcodes, radio was just tuned a few days ago on a Aeroflex 3920.
Tech21
Was it working and then started having the issue after tuning or was the issue present before tuning?
Tech21
Would you be able to PM me the codeplugs for both radios? I am kind of bored and wouldn't mind helping look for what might be causing the problem.
nhfdcadet
CETsr
New Hartford, Ct
are they both programmed the same other than having different flashcodes?
Have you tried exporting/importing the whole codeplug?
wa8pyr
Staff member
Lead Database Admin
Ohio
Yes you can (sort of). Just do a top-level drag and drop in CPS from the one that works to the one that doesn't.
Make sure to save the originals so you have something to fall back to in case it makes things worse.
