APX APX6500 "USB OVERCURRENT"
K2NEC
I've noticed a couple of threads on this topic previously however they have all been with portable radios. While installing a new radio, after plugging the normal hand mic in (a confirmed working hand mic) I started experiencing a USB overcurrent error. I took the mic out and replaced it with another mic that was confirmed working on a different radio. It displayed once and went away. Does this mean that something is wrong with the mic itself or maybe the port on the O5 head? Photo attached
Tech21
It simply means the USB device, in this case, a mic is drawing to much current from the accessory port. Most likely the hand mic has short somewhere in it.
If it was a port issue, plugging in your programming cable would probably tell you that a USB over current issue is being detected and either your computer would shut the port off or shut itself down.
