No UHF = Fail :lol:
Me however- I would like to have an Apex portable for:
800Mhz Smartnet type II for where I work.
VHF for 2m HAM TX and a heap of fire and rescue services receive only.
Throw in FPP to truly make it sweet!.
Commscanaus.
No they didn't forget UHF, what everyone is missing is the APX meets the TIA receiver specs. The Liberty does not. /\/\ could have easily added UHF but would have lost globs of sensitivity, and selectivity. The reason its 7/8/VHF is those were the easiest to impliment first. You will see UHF in 2010 or 2011 most likely.
Hello.
The Thales radio operates on one band at a time, no dual receive.
This is not a problem, as the radio can switch bands instantly.
A dedicated antenna is a great improvement on the Thales Liberty, as what comes with the radio is an improved dummy load.
This is true of most if not all multiband talkie antennas.
That Motorola thing looks odd now, but could easily be the future of talkies to come.
On the Thales side, all bands but lowband, P25 conventional, full support for both P25 as well as other forms of encryption.
On the Moto' side, VHF or UHF plus 700/800, no 900 support, P25 and type I,II,IIi trunking, P25 as well as several forms of Moto encryption.
The Thales tactical radio (military) has support for up to 2 extra encryption modules and in this manner can do Motorola encryption by inserting a Moto module.
It is not known at this time if the Liberty has this also.
Hello.
True, the earlier Thales radios can not accept any encryption modules, but,,.
The radio has had a major redesign since that time.
Now, the Thales military talkie can do USB as well as serial, and since the new logic board is smaller, a place for encryption modules.
Motorola and Thales were going at it, as the very first Thales radios could do Motorola encryption in firmware only, and Motorola was at odds with this.
The only reason for doing encryption in modules, and only the US and Canada models are equipped this way, is a legal one, the "foreign" models do pretty much all of the standard encryption and trunking.
As far as the Motorola radio goes, the Military version , non-FCC type accepted, does 40 to 550 MHz without any gaps, but of course is not TIA approved.
This is not called the APX7000 or anything else for that matter, it is undergoing testing at Ft Gorden Ga.
But, in essence, the same radio.
And, FPP makes the radio no longer FCC approved, one of the requirements is that the radio not be user reprogrammable.
Right now, Motorola is having issues with how the antenna interfaces with the radio.
Thales holds the patents on the active steering antenna, why Thales can supply one antenna and everyone else has at least 3.
Other than that snafu, the Motorola radio could be a 6+ band radio.
Once this is ironed out, the Motorola radio is expected to be a 136 to 175 MHz, 380 to 550+ MHz, 700 to 900 MHz, beast.
Note that this may be split into ranges, that is the maximum projected range for all variants combined.
The military model, not limited to pesky details like spectrum purity, can do much more.
Remember, quite a few military radios do not meet spectral purity for even the amateur bands.
Amateur radios are not noted for the receivers, why they pick up so much noise.
The Civil Air Patrol, like just about every federal entity, now must follow the new NTIA narrow band rules, so the new radios are much "Tighter" now.
Even the USCG aux now needs to use FCC approved radios on the AUXNET, but need not follow the more stringent NTIA requirements.
Marine radios are about the only place where a 30 year old radio is allowed.
Even Aviation has been hit.
The new radios do some really wild channel splits, and that is now mandatory.
So, it is not just getting the APX7000 working, it is getting it working under the new narrow band rules, and that means some real work in the receiver, while still allowing the thing to work in the older modes.
From 25 KHz spacing to 12.5 KHz spacing to 6.25 KHz spacing, all in one radio.
Remember, the Military models do not need to do 6.25 KHz spacing and meet TIA specs, just work.
That is if 6.25 spacing is even an option.
But, that is the complex nature of the world we live in.
Remember, this all started with NextHell and rebanding.
Facts be known, rebanding has just about bankrupted Nextel.
Sprint is none too happy right now.
But, 700 MHz, in effect an extension of 800 MHz, and new narrow band radios, as well as multi-band radios?
I am a happy camper.
Hello.
The Thales and Harris antennas are indeed active.
https://secure.thalescomminc.com/cart2/tcDesc.asp
Prior to the SINCGARS program, the radios had a tuning unit in the base.
Take a look at an AN/VRC-12 unit.
The AN/PRC-25 and AN/PRC-77 have a mechanical tuning unit in the radio.
The reason for this is the fact that a monopole can not work such a range.
If this was the case, one would not need to have a tuned antenna, but, be it talkie or mobile, some means of tuning is needed.
And, call it what you want, Thales calls it an "Active antenna".
Harris calls it an "Active antenna".
The patent is held by Thales, part of the French/UK consortium at the time.
Amazing as it must sound, Motorola had license but sold it as part of its military division, to Harris.
So, now that we have covered the simple stuff, the details.
There are several ways of doing a tuned antenna.
The easiest, and most effective, is to cut the antenna to 1/4 of the frequency.
Why 1/4? this provides a 55 +- ohm load and is resonant.
A 3/4 wave antenna will also work, but be not quite 50 ohms.
So, lets say the antenna is a 1/4 wave at 50 MHz, X 3 = 150 MHz, and a 3/4 wave, figure on a slight velocity factor loss and you have 147 MHz, good enough for 2 meters.
Now, to increase bandwidth we can do several things.
One is to make the antenna wider, the classic stovepipe antenna.
A Discone takes advantage of this also.
A discone need not be a solid unit, but can be just the outline, a run of rods works fine.
But, stovepipe or discone, it is just not going to work on your talkie.
So, another trick, we add a coil to the base, this makes the antenna a longer antenna, as the coil of wire adds to the circuit.
Now, if we add a switch and short out the coil it is shorter.
Roller or switch inductors in antenna tuners do this very task.
Fine up to a point, but, SINCGARS radios actually jump from channel to channel a bit over a hundred times a second in an almost random order, a switching circuit would have to be very fast, and there is a bit of loss in the coil of wire, our inductor.
So, we put the switching circuit IN the antenna.
EZ, right? you can only guess as to how it works.
Remember the flashing antennas for cellphones that run on nothing but the power of the transmitter?
http://www.101cells.com/flasan.html
Well, the antennas work in much the same way, except in place of a flashing delight we have an antenna that does something else.
Ever seen the lizards that change colors?
The trick a lizard uses is is a bunch of colored dots that can expand and contract.
The antenna works in somewhat the same way, but again, RF and not light.
So, there is a lot more going on inside that antenna than meets the eye.
It is clearly not just a monopole.
But, do your own research, the ARRL antenna handbook is an excellent start.
http://www.arrl.org/catalog/?category=Antennas,+Transmission+Lines+&+Propagation
Sorry if this seems a bit long winded.
My hopes are that there is a greater understanding of antennas and radio in general.
Both the Thales and Harris military radios are programmable in 100Hz steps throughout their entire range, no problem doing 6.25KHz, 5.0KHz or other steps.
