Priority-One
Can anyone suggest where I can get a VHF/UHF stubby antenna with or without GPS? I looked all over eBay but can find one.
You're very much incorrect. Motorola does make a shorter VHF/UHF short antenna for the APX series.If you're looking for a genuine Motorola VHF/UHF stubby antenna, you won't find one, because they never made such a model.
The only VHF/UHF antenna that Motorola makes is the PMAT4001, which is the standard 8.5" antenna for the APX series.
You'll either have to try to find something aftermarket, or you'll have to go with a single band antenna and compromise on the other band. Using a stubby antenna is already a compromise, so expect to have degraded performance no matter what.
i used this UHF antenna for years on my Jedi's, Astro Sabers, XTS radios, etc. I was very happy. But now I have a 8000 with the proper multi band antenna. I use my 8000 on UHF 90% of the time. How would you compare performance of the 8000 antenna on UHF vs the whip I have been using for years.![]()
I used the antenna from my XTS5000 and the reception is 1000 times better than the stock VHF/UHF antenna that came with the APX.
I'm mostly listening to uhf 450-512, so it's not affecting the VHF as I haven't used it yet.
It would be worthwhile to sweep each antenna on a VNA and measure S11 to see what the return loss looks like for each antenna. The results will show which antenna should perform best at a given frequency.The performance difference between both of the antennas is usually never noticeable (at least from my experience). In certain situations when I check the rssi the all band antenna will outperform the XTS UHF antenna but again I have never actually noticed any difference in the voice quality when transmitting and receiving.![]()
Are you comparing the older antenna to the newer XPR UHF/GPS antennas, or UHF only antennas? I've had good results with the XPR non GPS antennas.probably doesnt matter much but from my personal real world usage the older style skinny UHF 6" antenna performs much better for me when compared to the newer thicker UHF antennas that come with the XPR6550 units. Same with the older vs newer UHF stubby antennas. (making sure the stubbys were in the same band 450-470 typically)
