APX8000 FDNY MDC
Rudy3145
New York
Does anybody know a quick setting change for the APX8000 to have the same MDC "chirp" on their TAC frequency?
Also, I don't see the revert channel selection for the emergency key. Is it possible to have the radio emgency alert on a different channel than not selected, while remaining on selected TAC. I want the radio to emergency revert the signal to our main ops frequency, while keeping the radio on our TAC
Thanks in advance.
Skypilot007
Medford, NJ
DOS muting in the MDC system. Enable that and you usually will get the chirp you refer too if the APX works the same as XTS radios. Can't help with the other question.
K2NEC
5F6
Conventional Personality>Personality>Signaling>Emergency Revert
Ant9270
The Green Weenie
On TAC they use the Tactical Public Safety signaling. Are you confusing that with the DOS muted MDC1200?
Firebuff66
CT
They use TPS, (Tactical Public Safety) the channel is set up as a Mix Mode channel with TPS enabled. It allows analog voice with digital signaling.
I hope the pic is readable
ff026
ff026
What the last 2 posters stated. It’s TPS and there is no muting for it.
