APX8000 Scan Question
sefrischling
New London, CT
Is the APX8000 limited to 10 channels when scanning trunked, like the XTS 3000 and XTS2500?
I am looking into this radio to combine three radios down to one, however the ideal scan list, mixed trunked and conventional, would be 14 channels.
ResQguy
Meh
channels or talkgroups? APX series can scan 50 talkgroups in Priority Monitor mode, 250 talkgroups divided between 5 systems in Multi System mode, and 30 channels in Conventional mode.
GTR8000
NY/NJ Database Guy
BEE00
The 2500/5000 can actually scan 15 talkgroups, I just can't recall if that's a hack or there's a simple trick to making it happen. Either way, it's well known and has been discussed for many years, easy enough to find on Google. Actually it's technically 15+1, since the priority talkgroup doesn't have to be in the scan list when using 'Selected', thus freeing up a spot.
In any case, no, the APX series (all models) is not nearly as limited. You can have up to 50 talkgroups per system in an APX scan list.
sefrischling
New London, CT
Sorry, Channels that can be scanned per scan list.
For the XTS 3000/2500 it is 15 channels that can be scanned for a conventional scan list, 10 channels that can be scanned for a trunked scan list , even if a mix of trunked and conventional.
Public safety for my town, the town immediately to my east and towns immediately to my west, is comprised of VHF, UHF, 800/3200 baud SmartZone Type II with digital voice and 800/9600 baud P25. The APX8000 looks like the obvious way to get this into a single radio making my life easier as I operate in a number of towns. That said, the core channels I monitor make up 14 channels I'd need in a scan list that is mixed trunked and conventional.
As for the 15+1, that is for conventional, not trunked with the Astro Saber, XTS3000, XTS2500 and XTS5000. Trunked is 10, not 10+1, even if mixed trunked and conventional in a single scan list. If you're saying the XTS2500 can do 15 TG per scan list, I need to go look at the CPS again, because I was always under the impresssion I was limited to 10 like the previous XTS/Astro Saber models.
Anyway, if the APX can handle 50 channels per scan list that is 36 more than I need ... perfect!
mikewazowski
Staff member
Central Ontario
Normally in a talkgroup scan, you get 10 scan channels. There's a hack which will allow up to 16 channels.
On the apx, with a mixed system scan, you get 10 conventional channels and up to 50 changes from 5 different trunking systems each for up to 250 trunking channels.
sefrischling
New London, CT
Thank you very much, that is exactly what I needed to know. Now to figure out how to fund the radio and go from four portables down to one. This seems far easier and more logical for working and making sure my pants stay up.
sefrischling
New London, CT
One more APX8000 question ... I think I have found all the info i need, except this ... is it possible to set up a Trunked Talk Group as RX only?
I'd like to add in the PD/FD from one town over, on the same trunking system, but if possible just add them in as RX only. My XTS3000 and XTS2500 do not allow for this, and while I've yet to "oops" , I'd just feel more comfortable if possible setting them up as RX only, as I do with some some conventional channels.
FL2WAYRF
As far as I know, you can only set a TRS personality as rx only. So if you duplicated the personality, just set the second one as rx only and add in those specific tgs. Now this will still result in affiliation whether or not that is an issue for you.
sefrischling
New London, CT
Thanks Austin.
Affiliating isn't an issue, my 3000 and 2500 affiliate with the system and IDs work for all departments and towns on the system. I just always get a tad panic'd that I'll hit transmit by accident on another town's channels when listening in. I have them in the radios now, but would prefer to have TX inhibit if possible.
FL2WAYRF
Thanks Austin.
So what you can do is go into the CPS and under your menu options add TX Inhibit. Do that for trunking menu. That should work for your case.
GTR8000
NY/NJ Database Guy
BEE00
Well not really, since he needs to transmit on some channels/talkgroups. TX INHIBIT is a radio-wide option, and will disable all transmitting (conventional and trunking), including authorized registration/affiliation.
Put the RX-only talkgroups in a separate personality that has the Transmit Mode set to TG/AG Disabled. You can then add those talkgroups to a zone and scan list, and won't be able to transmit on them, without affecting anything else in the radio.
FL2WAYRF
Correct that is what I initially suggested.
