APX8000 wi-fi enable/disable
ResqChief201
The Flashcode option for Wifi must first be enabled in your radio. Without this flashcode option, you will not have access to it.
If it has Wifi in the flash, first start by putting the wifi menu button in your radio menu from the radio ergonomics tab in CPS.
Next you need to ensure that the Wifi box is checked for it to be turned enables. You can do this either from Radio Wide or Data wide. It's one of the two I believe.
Once that box is checked you can write the radio and you should be able to turn Wifi on and off from your radio keypad
N9IIT
Westfield, Indiana
Just out of curiosity what does the wifi on a /\/\oto handheld get you? Is this a hotspot or the ability to communicate over WiFi instead of OTA?
slyons01
Honestly I don't know. I am very new to this.
I was thinking OTA and WiFi update's were the same. So that shows you how much I now about the software. And tips of v video links would be helpful
W8VFD
Northeastern Ohio
One use is that you can program the radio via wifi, there may be other uses but that's the only one that I'm personally aware of.
slyons01
We in the process of purchasing over 700 radios mostly apx 8000 and 8500. I was hoping they could be program via CEP software via wifi. I thinking the more I do my research, the more I know I don't know what I'm doing. Lol
TLF82
Texas
It takes the Moto infrastructure to program them over wifi... You can't just have a wifi network in place and program a single or fleet of radios.
slyons01
Where can I find more information about this Moto infrastructure ? And is programming over the air same as Wifi?
otter9309
On the move
CPS with radio management is all you need. Your SW license will cover the fist 100 units, but you will need to purchase a license for additional radios. WiFi will support Codeplug and Firmware updates.
slyons01
Thanks. By any chance you know the price for the additional licenses?
