APX8500 conversion from an 03 head to an 07 head
ScanBoston
Boston MA
How easy is it to change an APX8500 that is set up with a 03 head to an 07 head if you have all the parts? Is this something that can easily be done in the programming or is it tricky?
Mr_Boh
The Land of Pleasant Living
Since it's basically already a remote mount, there are no hardware changes, you just need to make sure the programming is set, fairly simple, and can be done in advance since the codeplug has control information for all types of supported heads.
nhfdcadet
New Hartford, Ct
In the programming there is configuration for all of the different heads, depending on if this radio was already programmed for an 07 or not, you may not need to do anything at all other than connect the head.
