APX Apx8500 remote unit won’t power on
Rlosycer
I wired in my apx8500 with 05 head and DEK siren to a 12v power supply temporarily for programming purposes. Unfortunately, I failed to notice a stray ground wire touching one of the pins on the VIP connector on the back of the dek. When I plugged in the power supply the siren amplifier made an audible air horn sound and then the radio turned off. Now I can’t get it to power back on. Is there an internal fuse in either the control head or the brick that may have been shorted out?
Tech21
Did you have the fuses in line still on your cables going to the power supply?
Yes, there are internal fuses. Somebody with access to the detailed service manual can probably post screenshots or share the manual.
Do you have a multimeter?
Have you check the voltage output from your power supply to make sure you didn't fry it?
Have you taken the dek and control head out of the loop and only powered on the transceiver itself and plugged your programming cable directly to it?
Rlosycer
I had inline fuses but they may have been too large because they didn’t blow. Also I don’t have a programming cable that will fit in the transceiver, I only have the one that plugs into the mic port on the front of the control head
Tech21
It's identical. On a remote mount 8500, you have, from left to right, 1 programming port and 2 control cable ports. It may have a dust cover on the programming port.
Rlosycer
Gotcha I see that now. I Apologize, I’m new to these radios.
I’ll power up just the brick and see if I get anything with the programming cable in CPS
