I treated myself to an AR-DV1 for Christmas. To be honest, the device is not a favorite, the AR-DV1 just looks too ugly for that and in terms of operation it is not exactly intuitive to use. But the features in the area of digital modes and the continuous product development (regular firmware updates over the years) convinced me.
The included power adapter was criticized in some AR-DV1 reviews in Internet forums. What are you using? I once hung the supplied PSU on an oscilloscope and identified glitches in the range of 5 to 6 MHz (I'm just an amateur - the measurements can also be incorrect). At my powerstation (disconnected from the normal power line) I get interference signals in the range of 1 KHz at the 12V output, which probably shouldn't disturb the scanner too much. A power bank of mine has far fewer interference signals on the 12V output, but at 200 KHz.
And then another question: Is it normal when you turn on the AC adaptor/PowerStation/PowerBank and they are connected to the AR-DV1 (which is not turned on !!!) that the display flickers briefly?
