G7HID
AR-DV10 Receiver Firmware Version 1812C Update Jan. 16, 2019
Feature improvements:
- Power-save function added. To activate it, MENU + 7, then go to page 2/3.
To reduce battery drain, this function cycles sleep/awake state by the ratio 100ms awake / 900ms sleep.
Note: When the power save mode is set to ON, following might be noticed:
Some displayed characters might look thinner than usual.
The first few milliseconds of a signal's audio might be truncated in some cases, especially in digital modes.
During SCAN/SEARCH, power-save is automatically disabled.
For full performance, set the power-save function off.
- LOG REC feature added. To activate it, MENU + 7, then go to page 2/3. (Can only be activated when SAVE TYPE is set to AUDIO)
Logs of audio recordings are written into the wav file. Use the PC utility **LOGEXTRACT** to access the logs and playback related audio files on your PC.
-Sound gain feature added. To operate it, MENU + 7, then go to page 2/3. Can be set from 01.00 (normal) to 15.94 (loudest)
To be used only if maximum sound volume obtained with VOL ATT set to 00 is insufficient.
AR-DV10 | Firmware Updates | Download Area | Support | AOR,LTD. Authority On Radio Communications
Mike
Mike
