ARC 260 Failing to Save Settings
smcbmt
Is ARC260 having a know issue saving the BCD160DN's Settings? Downloading, saving, editing of channels and banks is fine. It seems to fail saving simple configuration setting like display settings. Something some setting are saved when downloaded from the scanner to the file but not all. The simple aren't there after downloading having reset to factory default. It is getting old having to go through the scanner's menu and reset general preferences every time i power on.
Thanks,
Steve
tvengr
Well Known Member
Baltimore County, MD
Are you clicking on OK after changing the settings?
tvengr
Well Known Member
I tried doing a test with ARC260. It is not saving all of the display settings. Once the file is closed and then reopened, the changes are gone. It looks like some bugs in the software. I have version 1.02 Build 2.
smcbmt
Yes that is what I am experiencing and that is my firmware version.
sallen07
Rochester, NY
What did Gommert say when you told him about the issue? You did report the problem, yes? Gommert is here, and there is a "report a problem" on the Butel website ....
