Arc 536 Pro not reading UBCD3600xlt
Skirgey
My head is hurting with is.
I took a pdf of mil air freqs converted to a csv file so I can import it into arc but arc will not read my ubcd3600, it connects fine as virtual control is working in serial mode.
If I switch scanner to usb mode and click read in arc it directs the scanner but does not load the fav lists, so I cannot read from or write to the scanner.
it is the full and latest version of arc 536 pro
Skirgey
Hi yeah as I say it connects but no favs show and scanner is full of fav lists
Butelsoftware
Dayton Hamvention
Can you make a zip copy of the contents of your SD card and email it to arcsoftware at yahoo dot com ?
Also there should be a file called "drivetest.txt" under My Documents\My Scanner Data Files\ARC536PRO
I like a copy of that file too.
Gommert
Butel Software
