ARC536: ARC 536PRO With Uniden SDS 100
#1
I am using the Butel ARC546PRO to control my Uniden SDS 100. I am monitoring an APCO P25 trunked system. On the display it shows as follows
TGID: 3750
TGID: 3750
How can I configure this so it shows the TGID on just one line and the Talkgroup Name on the other line?
TailGator911
Fairborn, OH
#2
Not sure about how to do it in Butel, but with the Uniden Sentinel software you can pick and choose and place where your detailed info will appear on the display screen, as well as customize your own color scheme.
JD
kf4anc
