ARC-Easystream
mikea7531
South Bound Brook NJ
Wouldn't it be a good idea to create a Wiki for 'Easystream Scanner Streams" where we can list the connection info the streams and more detailed info about each of them?
Butelsoftware
Dayton Hamvention
That is a good idea since there are quiet a few streams out there,
also the plan is to have a dymamic list in the ARC-Eazystream client,
so every time you start the client it loads a list of most up to date streams but is still being developed.
Gommert
www.butelsoftware.com
bear105
Any plans to release clients for Linux or other OS's? Also, has there been any consideration for a client in Java format that would work across numerous OS's?
Chrome69
Ontario, Canada
I have setup mine, not sure if its working or not. Had alot of problems with my Linksys router.
peel.dynalias.net
Audio Port: 8100
Data Port: 8101
Currently is set for Peel Police and Mississauga and Brampton Fire.
Their maybe a hum with the audio and i know the problem is a bad cable, just want to see if its getting out...
Chrome69
Ontario, Canada
thats what i have set up currently, but its still blocking it.. :(
pinellasfirefighter
seminole fl
i bought the program last night... i love the arc eazy stream.. its well worth the money.. if you guys wanna listen in my addy is..
pinellasfirerescue.no-ip.org
audio port 8100
data port 8101
p.s. gommert since i bought this porgram will i get all updates and new versions of this program also?
scannerfreak
Moderator
Indiana
Do you have a firewall? You may need to add an excpetion for those ports there as well..That's what I had to do..Also make sure your IP is actually .1 and not like .102 or .103, Just using .1 I did not have any luck, I had to change it to .102 to get it to work. I have the exact same router..
scannerfreak
Moderator
Indiana
Here is my setup
Make Sure the 3rd box in unchecked. Using this config it is working perfectly..
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
Brian and Scanner_Freak,
I too have Linksys, but don't have anything in the control panel or program files for those setup dialogs. Where are they located?
Chrome69
Ontario, Canada
I seen one little problem, the Linksys isn't up to date on firmware.. just did that now.. yes i am on a fixed IP Just did the ajustments scanner freek has
Chrome69
Ontario, Canada
Fmom make sure you have the latest firmware for the Linksys. Thats what i noticed i was running 2. something and the latest is 4.30.5
