ARC X36 Basic
newsnick175
Denver, North Carolina
Having issues with "Justify Tags". Centering alpha tags does not center them in the first 24 character line. Right isn't accurate either. Also, only channel tags do not allow you to hover over the text to show the number of characters. Is this because its "Basic" and "Pro" resolves this issue? This is slowing me down big time!
ofd8001
Louisville, KY
In the earlier editions of the Pro version, there were some issues with correct justification. However the most recent release seems to have addressed this.
Have you checked to see if you have the latest release? (Help>Check for Updates).
ofd8001
Louisville, KY
If you do that Help>Check For Updates (The help column is on the top row, far right side), a pop-up window will appear. That window will say "You are running the latest release" or take you through the steps to download the latest release.
