ARC XT Basic
Junior08
Cape Cod
Using this software (after a lengthy absence) to program my BCD996P2. I have about 15 systems programmed. I go into scanner>configuration editor, and make some edits such as my welcome screen and background colors, I then save everything as a profile. When I go back to the same profile later everything is saved except for the edits I made under configuration editor. I have the small P2 models box checked off down at the bottom also. I have tried this several times yet configuration editor never saves my work.
Any ideas why this is happening? Any help appreciated, thanks.
Junior08
Cape Cod
I am a long time user of Freescan but I'm using ARC to program DMR in my 996P2, which Freescan does not support.
druhe
Southwest Pa
Configuration is a separate file. Mine for example is 996P2config.cgf Go to the config editor at the bottom there should be an open tab, look there
