ARC XT Pro and No UID's
ecps92
Taxachusetts
I've had my 396xt running for quite awhile and finally getting around to using the logging software [ARC XT-Pro] for unattended monitoring [mainly P25 UID's]
The Radio it self shows the UID's [Non Enc] fine, when programmed as Single Freq Trunk, however the Software is only logging the Frequency as in use, but No UID's. :confused:
Thoughts/Comments/suggestions.
396XT / Win XP / Panasonic Tough Book and running ARC XT-Pro Ver 1.7 Release 2
FYI - UID's and TG ID's do show up for the Trunked systems.
ecps92
Taxachusetts
If they are not known, how do you tag them?
PS - these are P25 Radio/Conventional not Trunk, however using the Single Freq Trunk method.
I want to let the software sit and capture the UID's on a single freq for a 24 hr period.
Did you tag the UIDs?
Tagged UIDs cannot be logged unless you start the tag with 'UID:'.
Gommert
Butel Software
ecps92
Taxachusetts
Display mode? Well which one ? is best for SINGLE CHANNEL trunking aka the ability to watch UID's on a P25 Freq :confused:
The UiD's show on the Radio, but not in the Software.
A little more experimentation shows that you CAN NOT manually go to a channel to be logged. You need to quickly capture it [hit hold, during the transmission] for the software to log a UID.
If the UID is shown on the display and starting with UID: it should be logged in the grid.
Also make sure you selected the correct display mode, not all mode show UIDs.
Gommert
Butel Software
