ARC-XT Pro Bug ???
Dewey
Is anyone else having problems when trying to load a configuration file from the drive? For the past couple versions, I get an error code "380" crash, and ARC-XT Pro just closes anytime I try to load one of my stored configuration files. I had this problem either last year or year before with the regular ARC Pro programs, but it went away after a couple of revisions.
Dewey
Dewey
Gommert...
Through some trial and error through the process of elimination, I didn't make it past the first configuration screen, "Close Call". I have noticed that the error occurs when I attempt to load a saved configuration where the Close Call back light is set to cyan. I can save and open a fresh and unaltered configuration file all day long, but as soon as I change the Close Call backlight color to cyan even if no other changes, the error occurs on my very next attempt to load the saved configuration file.
Dewey
EDIT: There is also something going on with the value that gets saved when Close Call Pattern is changed (CCALP), but I haven't been able to figure that one out yet.
trumpetman
Charlotte, NC
Hate to resurrect an old thread, but this is the only relevant thread I could find that might familiarize everyone with the problem occuring.
I'm also getting a 380 run-time crash when I try to load a configuration file in plain old ARC-XT (NOT PRO) The software is version 1.5 build 1. I've played with the back-light color and it doesn't seem to help, and it seems you've either removed the CC Alert settings or I've gone blind.
Thanks!
