Hello to those at BuTel software. I know you've stated you have not looked at the compatibility between ARC-XT Pro and the BCT-15X, but I implore you to step up this investigation. The virtual control function is pretty much useless. Other than the numeric keypad, volume, squelch, scan, manual and L/O the other software keys don't function as labeled. The programming section has options not available on the 15X, and some of the functions do not work correctly once sent to the scanner.
Thank you for listening.
