Zippomeister
I'm running Version 1.4 Build 5 of ARC XT Pro. (ie the latest greatest)
It's the "full" version (ie I paid for it)
Windows 32-bit Vista, w/all latest updates
Using Uniden cable w/ Prolific driver (i.e. USB-to-serial converter cable)
Have uninstalled/re-installed program
ARC XT won't recognize either my BCT-15X or BC346XT.
When I ask the program to "autodetect" it complains there's no scanner hooked up.
When I manually designate the correct COM port, same result when it tries to read from the scanner.
Ok, many folks around here are running ARC XT without this issue, so the basic software can't be all that bad.....any suggestions on other items to check, or known incompatibilities??
Thanks, Zip
Thanks, Zip
