Arc160
spooney
Indiana
I have a Pro-162 and I am testing the ARC160 DEMO, but I don't see any way to turn the TG scan lists on or off in the program. Was this over-looked or am I missing something??
kd7ckq
No. AZ
I don't see it either. I am also using the Demo version. The manual is no help either, the pictures do not match the program.
spooney
Indiana
I noticed that the screen shots in the software manual are for ARC300. I'm having trouble programming an LTR system. The data transfered to the scanner ok, but I can only scan in OPEN mode and the TGID alpha tags do not display during a transmission. I have attached my .rsf file if anyone wants to look at the LTR in bank 0 and see why it won't scan that bank in CLOSED mode only in OPEN mode.
  • pro-162.zip
kd7ckq
No. AZ
008151 is not the correct format for a LTR system. So 008151 should look like '0-08-151'. It's a simple fix.
008153 Chandler PD Pvt Off
008048 Chandler Fire Off
Should look like;
0-08-153 Chandler PD Pvt Off
0-08-048 Chandler Fire Off
Butelsoftware
Dayton Hamvention
Both formats are valid in ARC160. Either 008153 or 0-08-153 will upload correctly.
Gommert
www.butelsoftware.com
Should look like;
kd7ckq
No. AZ
I was entering some freq. and I accidentally selected FM for a AM channel. Now I noticed that there is NO AM, NFM, or AUTO selection for channel modes. The Short cut keys do not work either, 'N' for NFM or 'A' for AM.
Software is not as polished as there previous offerings, seems rushed.
Tom_G
Rocky Hill, CT
For LTR systems, No matter if I use the dashes in the talkgroup ID or not, I never get the talkgroup alpha tags to display when scanning. Only the ID's display.
EDACS and Mototorla systems work fine....
Any suggestions.....?
spooney
Indiana
There is a problem with the upload of LTR data to the scanner when using ARC160. i got mine to work by manually re-entering the TGID's into the scanner with the keypad.
Tom_G
Rocky Hill, CT
OK, So after re-entering the talkgroup ID's manually, the alpha-tags will start displaying ?
Thanks for your help.
Gommert, Are you aware of this issue ?? Thanks,
spooney
Indiana
It worked for me. You don't have to re-enter the alpha tags, just the TGID's and use just the numbers. No ( . ) Dot
Tom_G
Rocky Hill, CT
OK, That seems to work for me now also.
I then had ARC-160 re-read the data from the radio and it displays that ID's with no dashes.
I think their may be an issue with the software because even trying to edit the ID's seems to yield strange results. ( I had tried adding dashes in the talkgroup ID field and the dash does not always show up where you typed it.)
Hopefully the Butel folks will read this thread.....
spooney
Indiana
LT Programming
The problem with uploading LT programming from ARC160 appears to be a firmware issue that R/S will have to address. For now though you can still use ARC160, but after the upload you will have to manually re-enter the TGID's into the scanner using the keypad. The alpha tags upload OK, so you won't have to re-enter those.
