ARC246 and LCN's for EDACS
Pro-95
Washoe Valley Nevada
Does anyone know if you change the LCN number order only in the system frequency list by the number order in the LCN column.... Does that really change the LCN order without moving the frequencies around?
I'm asking because I will be taking a trip on 80 again and I will be taking the BC246T and my laptop and it would be really cool to do some on the fly programming changes to see what if any of the Nevada Shared Radio System sites are up and active along the 80 corridor across Nevada.
BTW, I thinK I will be buying one of these scanners. This bad boy is pretty cool. I almost have the entire NSRS sites and WCRCS sites loaded into this scanner. :shock:
Hopefully the ARC396 will use the same files as the ARC246! - hint- -hint- -hope-
