Arc246 shuts itself down.
tony6868
Stow Ohio
After about 2 minutes, arc246 shuts itself down. I have checked my firewall and reinstalled the program.
I can open it and do some data entry. Even save files. It works fine for about 2 minutes. I once saw a "time loop" notice but I don't get a notice of a conflict or anything anymore. I have tried to contact Butel and gone in other discussion groups as well. Saw that another user had the same problem and someone from Butel had a few "try this" but no final thread to a resolution.
kellykeeton
Oak Harbor, Wa
you own the full copy I assume? the software is sort of old and buggy, try going into the registry and clearing any keys for it, also try installing a C++ runtime and make sure all your runtimes are working correctly, whats your OS and computer date?
DonS
Franktown, CO
Couldn't hurt! :)
I suppose :)
The question then becomes... which C++ runtime ("a" C++ runtime doesn't do much good - though, as mentioned, any old runtime probably couldn't hurt)? I guess it we'd be talking about MSVCRT.DLL, which is a ways down the dependency chain from MSVBVM60.DLL (i.e. under OLE32.DLL).
However, if my copy of MSVCRT.DLL was "old" or "damaged", I'd be worried about a bit more failing on my Windows PC than just one scanner program.
tony6868
Stow Ohio
Arc 246 shut down
I have a one year old Dell running Windows XP. I am now using Freescan, however I did pay 30.00 for the full version and that doesn't make me happy.
tony6868
Stow Ohio
I might try this: arc 246 shut down
The loop timeout has nothing to do with file permissions, despite what Lou says. As you've figured out, it has everything to do with serial I/O. It typically crops up when Windows thinks it might be seeing a mouse on a serial port, which leads to the application losing data.
I had the same problem under XP with a real serial port until I told Windows that my 246T wasn't a damn mouse.
In XP (don't know if Vista is the same), My Computer / Properties / Advanced / Startup and Recovery (Settings) / Edit;
This will load boot.ini in Notepad. Append " /fastdetect" as shown here:
[operating systems]
WINDOWS="Windows XP Professional" /noexecute=optin /fastdetect
and reboot (naturally)
From http://support.microsoft.com/kb/833721
"If you use /fastdetect, and you do not specify a communications port, serial mouse detection is turned off on all communications ports."
After doing this, I've never seen another "loop timeout" from ARC software. I don't know if this information is of any value to Vista users, but there it is.
kellykeeton
Oak Harbor, Wa
Does installing a C++ runtime help programs that are written in Visual Basic?
no it wont hurt, I guessed as I havent ran but-hell software for a while I remember it was visual code, go get the VB6 runtime and the .net runtime and install them as well that way you renew all of your OCX and DLL files.
