ARC246 + SmartZone
yorkphotog
Toronto, ON, Canada
Right now I've got the Toronto Public Safety system programmed, and I want to add the Ontario Provincial Government's Fleetnet system. To try and keep things organized, my plan was to add the Ontario freq's to the existing SmartZone system that I have programmed, and then just add the groups that I want to from there. I did so, sent that data to the scanner, and it doesn't pick up any Ontario Government stuff, just Toronto Public Safety. Is what I was trying to do possible, or was I just not going about it the right way?
Thanks.
IdleMonitor
The Ottawa Valley - Eastern Ontario
Unforunately, Toronto's system is 800 mhz and Fleetnet is 142 mhz. You need to make them seperate systems. You can keep the same quick key # but they have to be built as seperate systems.
