ARC300 and Pro-163
Pressman39
London Kentucky
I have a Pro-163 Radio Shack scanner and I just purchased the ARC300 software to download the frequencies into the scanner. I have the software downloaded and it seems to be working. But I can NOT get the frequencies to transfer from the software to the scanner. any suggestions?
zonesecur
Quebec
ARC300 vs PRO163
Well, keep it simple. IT DOESN'T WORK
Good cable, rigth USB port, ver 1.07 (pro-163 new), ver 1.21 build 6 Full (butel) and windows with a transfert progress line. Everything looks good. But:
1. The name Radio-Shack replaced by PSR-300
2. No Frequency, no funny
What's wrong ???....
JamesPrine
Ponchatoula, Louisiana USA
There's a little box that you can choose the exact scanner you need to program, if I remember correctly, ARC300 supports several scanners.
And be sure you take remove the cable extender that ships with the Radio Shack USB programming cable so it will communicate properly!
Good luck!
danyb50
The right comm port has to be chosen from your Device Manager,Hardware ,Ports.Sometimes it is comm 4
