arc300 c/p bug
kamikaze1
greenwood sc
i was wondering when this bug will be fixed for arc300
when i go to database and c/p freq over to arc300 it copys but on upload to scanner i find it defaults everything to search! when PL or DPL is at the end of a DPL tone / CTCSS tone even when u save it with arc300 it really bugs me that i have to add everything again not to mention waste a whole day adding them manually to each freq can we get a fix for this its so annoying
have nice day
KAZE
kamikaze1
greenwood sc
in short when i copy and paste freqs over to arc300 form the database it has DPL or PL at the end
EX 154.1600 | alpha tag | 606 DPL
so when i copy that to arc300 everything is fine but when i upload to the scanner the DPL must confuse the program/scanner and makes it default to search even when i save a file with with DPL or PL in the pl/dpl channel and when i exit and reopen everything is defaulted to search too
thnx for the reply
kaze
Butelsoftware
Dayton Hamvention
A direct copy/paste this way will not work unless you add a step and remove the DPL text, it is easier to use the direct Radioreference webservice and import data that way.
Gommert
Butel Software
