ARC300 for PSR-300
bumpbailey
I am using the software now, I know the frequency and mode, but not sure what to put into the fields for;
PL/DPL
Attenvator
Delay
Lockout
Also, not sure what to put in on the BANK screen for trunked info.
Please help!
(I live in Medford, MA just outside Boston)
Thanks!
gmclam
Fair Oaks, CA
PL/DPL <-- This is optional, you can usually just set to FM
Attenvator <--- OFF
Delay <--- ON
Lockout <--- OFF
Put whatever you want there. It is just text that describes what you programmed in to the bank. It could be "fire" or "County" or "City" or .....
bumpbailey
Attenvator <--- OFF
Delay <--- ON
Lockout <--- OFF
thanks gmclam!
I labeled the BANK but there is another section for "type", I selected Motorala, but there is also EDACS, LTR, and not trunked.
gmclam
Fair Oaks, CA
If you are programming a trunked radio system (TRS), the scanner needs to know which type it is. These scanners only support 3 types of trunked systems: Motorola, EDACS & LTR. Select the type that matches the TRS you are programming.
