ARC396 Installation Problem
bacon
Tippecanoe County IN
I use Windows XP Pro with SP2 and I keep getting an error message when trying to install Butel’s ARC396 software that says:
"Error 1402.Could not open key: UNKNOWN\RICHTEXT.RichtextCtrl.1\CLSID. System error 5. Verify that you have sufficient access to that key, or contact your support personnel."
I understand from the manual that I need to set the “DPI setting;” to small fonts by navigating to the “General” tab by clicking “Advanced” on the “Setting” tab in “Display Properties”. The problem is that I do not have the "Small size" option. I only have options for "Normal size (96DPI)”, "Large size (120 DPI)" and “Custom setting…".
After hours of research on the internet I found a few articles that said “Normal size” in XP is the same as “Small size” on Windows 2000, 98, and Millennium but knowing that doesn’t help because I still can’t install the software.
Is there a way to add the small font option without reinstalling XP? Is there a way to change the “Normal size” to read “Small size” so the software will install? Am I missing video driver or XP files?
Please help with a solution to this problem. I really want to use the software and although I haven’t been able to use the key, I don’t know if I can get my money back.
John_M
Rochester, N.Y.
Sometimes you can add a space in the beginning or end of the key without knowing it. I always paste my keys in and then put the curser at the end of the key and press the delete key.
bacon
Problem Solved
Thanks for the suggestion but it was not a problem with my registration key it was a problem with Windows XP registry keys. I had to give full permissions to the SYSTEM key that was referred to in the error message.
P.S.
I actually did have a space before a password once and called our computer support people and they figured it out immediately. I consider myself reasonably computer savvy so you can imagine my embarrassment when they pointed out the space.
