Has anyone seen a newer beta for ARC396PRO Beta? I like the new features, but it's very unstable. I was hoping to see a new beta or a new final version soon. thanks.
DaveIN said:0.910 is the current beta available to those who pre ordered.
it usually crashes anywhere from 5 mins to a few hours. this happens on 2 different PCs...one I built and a Gateway at work. I used to have issues with v1.042 crashing as well but I was able to fix it with setting compatibility mode to Windows 98/ME. I tried it with 1.05 but it's even worse. both PCs are running Windows XP SP2. there is really nothing else install in common on either. one thing I noticed after they crash, the EXE is still running in the task manager. I have to kill it manually. most times, it's using about 50% CPU and gobs of memory. it does crash or stop talking to the scanner is I am using Ghost32 with an USB to HDD adapter. I can see this since it is taxing the USB controller heavily.Go-24 said:I have never had a problem with 1.05 ... whats happening for you?
That's what I was thinking ARC996, sorry.mike_s104 said:ARC396PRO? the beta I have is 1.050. why would I need to pre-order software that's already out? also, if I bought the full version, would it be reasonable to have access to the beta versions? I checked Butel's site and failed to find a working link for any beta version.
maybe you're thinking of ARC996PRO
no big deal...DaveIN said:That's what I was thinking ARC996, sorry.
Arc396 is a bit unstable (1.042 and 1.05) and on my system(s) as well. Sometimes it hangs and sits there and flashes like a strobe light in the task bar requiring a task kill to close it; and it occassionally forgets to upload a system when more than one is selected. The user interface is downright awful, and there are so many other glitches in the software I don't know where to begin to make a list for the development team.mike_s104 said:Has anyone seen a newer beta for ARC396PRO Beta? I like the new features, but it's very unstable. I was hoping to see a new beta or a new final version soon. thanks.
are you using a serial or usb cable?mike_s104 said:it usually crashes anywhere from 5 mins to a few hours. this happens on 2 different PCs...one I built and a Gateway at work. I used to have issues with v1.042 crashing as well but I was able to fix it with setting compatibility mode to Windows 98/ME. I tried it with 1.05 but it's even worse. both PCs are running Windows XP SP2. there is really nothing else install in common on either. one thing I noticed after they crash, the EXE is still running in the task manager. I have to kill it manually. most times, it's using about 50% CPU and gobs of memory. it does crash or stop talking to the scanner is I am using Ghost32 with an USB to HDD adapter. I can see this since it is taxing the USB controller heavily.
I'm computer savvy (do it for work) so I don't have anything like spyware or virus related. nothing installed or running that's not needed. one PC (Gateway - work) is an Intel P4 and the other an AMD Athlon 64 X2 Dual-Core 3800+. the Gateway has 1GB DDR RAM, SATA HDD, Intel chipset on the motherboard. the AMD has a WesternDigital Raptor 10,000RPM SATA HDD, 2GB DDR PC4000 RAM, Asus A8N-SLI motherboard and an Nvidia GeForce 7600GT PCI-E video card.
serial cable with a serial to USB adapter. I used this cable on my old computer without issues. things only started acting weird when I started using my new PC. as I said before, I am computer literate and know to update things to a point...other times you should leave things alone if all is well. I only usually have a browser, Outlook and AV software running (other then what loads with Windows). I don't think it's software or OS related but rather hardware. I am NOT going to run Windows 98 on a PC just for some software issues that are supposed to work on Windows XP. I like the software and for 80% of the time it's fine. I also have issues with deleting data then loading data. if I do them in seperate steps (open "send data" delete systems, close window then open "send data" again then send the data I want) everything is fine.wesct said:are you using a serial or usb cable?
i use the arc396 pro on a machine that dual boots with windows 2000 and 98se and have had no issues with the software. the next question is: what is running in the backround while using the software? and are you up to date with microsoft (windows update)?
i would also send an email to gommert at butel to see what ideas he may have
wesct
