Has anyone seen a newer beta for ARC396PRO Beta? I like the new features, but it's very unstable. I was hoping to see a new beta or a new final version soon. thanks.
DaveIN said:0.910 is the current beta available to those who pre ordered.
it usually crashes anywhere from 5 mins to a few hours. this happens on 2 different PCs...one I built and a Gateway at work. I used to have issues with v1.042 crashing as well but I was able to fix it with setting compatibility mode to Windows 98/ME. I tried it with 1.05 but it's even worse. both PCs are running Windows XP SP2. there is really nothing else install in common on either. one thing I noticed after they crash, the EXE is still running in the task manager. I have to kill it manually. most times, it's using about 50% CPU and gobs of memory. it does crash or stop talking to the scanner is I am using Ghost32 with an USB to HDD adapter. I can see this since it is taxing the USB controller heavily.Go-24 said:I have never had a problem with 1.05 ... whats happening for you?
mike_s104 said:ARC396PRO? the beta I have is 1.050. why would I need to pre-order software that's already out? also, if I bought the full version, would it be reasonable to have access to the beta versions? I checked Butel's site and failed to find a working link for any beta version.
maybe you're thinking of ARC996PRO
DaveIN said:That's what I was thinking ARC996, sorry.
mike_s104 said:Has anyone seen a newer beta for ARC396PRO Beta? I like the new features, but it's very unstable. I was hoping to see a new beta or a new final version soon. thanks.
mike_s104 said:it usually crashes anywhere from 5 mins to a few hours. this happens on 2 different PCs...one I built and a Gateway at work. I used to have issues with v1.042 crashing as well but I was able to fix it with setting compatibility mode to Windows 98/ME. I tried it with 1.05 but it's even worse. both PCs are running Windows XP SP2. there is really nothing else install in common on either. one thing I noticed after they crash, the EXE is still running in the task manager. I have to kill it manually. most times, it's using about 50% CPU and gobs of memory. it does crash or stop talking to the scanner is I am using Ghost32 with an USB to HDD adapter. I can see this since it is taxing the USB controller heavily.
I'm computer savvy (do it for work) so I don't have anything like spyware or virus related. nothing installed or running that's not needed. one PC (Gateway - work) is an Intel P4 and the other an AMD Athlon 64 X2 Dual-Core 3800+. the Gateway has 1GB DDR RAM, SATA HDD, Intel chipset on the motherboard. the AMD has a WesternDigital Raptor 10,000RPM SATA HDD, 2GB DDR PC4000 RAM, Asus A8N-SLI motherboard and an Nvidia GeForce 7600GT PCI-E video card.
wesct said:are you using a serial or usb cable?
i use the arc396 pro on a machine that dual boots with windows 2000 and 98se and have had no issues with the software. the next question is: what is running in the backround while using the software? and are you up to date with microsoft (windows update)?
i would also send an email to gommert at butel to see what ideas he may have
wesct
