tvengr
Well Known Member
If you saved the file that you upload to the scanner, that is a gr5 file. If you click on Open with the ARC500 software, you should see the file.
Hello Gommert. Maybe you can help me with this issue? I have all the files that i want to enter into the scanner saved with corresponding scanlist numbers. Same thing is happening? After i download one county and then download the next it overwrites the first one i put in??? I just don't know what i am doing wrong. This particular scanner i programmed last year with no problem. it belongs to my sister. she wanted Volusia Co in FL in it. so when i put that county in it wiped everything out??? I don't know why i'm having such an issue reprogramming it. must be certain steps i should be taking or something i'm not checking off in the software??? You can only upload one thing at a time, so the issue will always be the same. Right??? Apparently I am not saving the files correctly or something else obviously? ThanksYou can not do partial uploads nor add scanlists, this is a limitation of the scanner not the software. To add new data first read from the scanner in the ARC500, then add the new data and upload back again.
To scan items/objects they must be assigned to a scanlist using the scanlist column. In ARC500 you can use scanlist preview so verify your scanlists layout.
Gommert
www.butelsoftware.com
Thank you. Appreciate it!You need to create one file with all scanlists, you can not just upload a scanlist or add data. Create one file with all the data and upload that one. Uploading data will always clear what is in the scanner. This is how the scanner was designed.
Gommert
