ARC996 v4 Default File Path Problem
matthewtomek
Live Audio Admin
Memphis, TN
I recently upgraded to ARC996 v4 (running Windows 7).
The default file path for v4 is c:\users\matthew\appdata\romaing\butel\arc996\data. I can't find that 'app data' folder when I try to find it
I changed the default location to c:\users\matthew\documents\my scanner data files\arc996. Once I click ok to save that, close the program, and open the program back up, it has reverted back to the software default under appdata\....
When I try to crate a new trunk system and save the new system, this is the error message I get:
Has anyone else experienced this and if so, have you found a solution?
thom
Connecticut shore
I've had the same problem on 2 different computers with Windows 7. I haven't found a solution either.
garys
Eastern MA
I don't have Windows 7, but in Windows XP files like that have the "hidden" attribute set on. I had the same problem with ARC996. I don't know how Win 7 handles that, but in XP you can turn off the hidden attribute in the "Folder Options" menu item under the "Tools" tab in My Documents.
jimvm
Olivehurst, California
Arc996t
I had the same problem using Windows XP. I keep getting that error box and could not close it!
I had to use task manager to kill the application.
Try doing a save profile first before saving the system. That worked for me.
jim vm
