ARCXT PRO on a small display computer
Mississauga, ON
I'm having a little issue wiht ARCXT on my small 10" laptop screen. When I open either the quick-key overview window or the group set-up window, they fill the screen from top to bottom not being able to access the 'OK' button.
On a normal PC monitor this is not an issue.
Also, on the set-up groups windown, there is no close button on the top corner of the window forcing me to ALT+DELETE from the program.
While these are not big issues, I really like the ease of these features.
My ARC996 PRO has none of these issues.
Any suggestions?
Helitac
Hungry Horse and Missoula, Montana.
Reduce Computer Settings
If using a MS Windows operating system, I would suggest you right click on you desktop which opens a small window. Click on "Personalize" and then click on "Display Settings" to adjust (reduce) your monitor resolution so more items fit on the screen.
You might also be able to get to your display settings via the "Start" > "Control Panel" > "System" (depending on what version of Windows you're running).
Helitac
