ARCXT pro software question
WALT13
LOUDON, NH
I am using ARC XT pro software for programing my BCT396xt, BCT996 xt & BCT15x scanners. My 15x was previously programed with only channels that used pl/dpl squelch codes.
I have moved from CT. to an area (NH) that uses P25NAC codes on their VHF frequencies. Using the same profile as my 396xt & 996 xt scanners, it appears that the 15x does not accept the P25NAC codes. I checked to see that they are in the current profile, and they work on the 396xt & 996xt.
As I had not used the P25NAC coding on the 15x due to its past location, I do not know if they were previously active on the 15x. As you might imagine, without the P25NAC codes active, all I get is static/noise
on those channels. The 15x is set in display mode 2, and displays standard pl/dpl codes when used
I was under the assumption that all three scanners could receive the same, with the exception of digital trunk systems. If you can help with a setting or clear up for me my error, it would be appreciated.
WALT
fxdscon
¯\_(ツ)_/¯
WALT
NAC codes are not supported on the BCT15x scanner. The BCT15x is an analog only scanner, it will not monitor any kind of digital transmissions.
http://wiki.radioreference.com/index.php/BCT15X
