Advanced News
Just before the first TETRA firmware was released, I had started a re-write regarding the AR-DV1's Memory Channel manipulation.
I wanted to make it much easier to change things, and find a way to 'force' the radio to add changes to the Memories automatically just by selecting an individual button on the Main window, Frequency, modes, different squelches, noise reduction and bandwidth settings etc, but still in real-time so Users could hear the results. All with a single mouse click.
Sounds quite easy when you say it quickly, but it was not. The radio is not designed to allow those things under serial control.
I shelved the project, and had to first concentrate on adding Tetra, then fixes re the firmware.
I went back to it a few days ago.
Soon there will be new functions re Memory Channels.
The new functions are not complicated, quite the opposite. The coding is complex, but the operation should make Memory Channel manipulation much easier, and still in real-time so Users can actually hear their effect as changes are made.
The original methods are still available, for those used to them.
The BETA has gone out to be tested.
I realise there have been several updates in the last few weeks, but they were necessary to introduce workarounds regarding firmware 1610B.
It has been over a year since I started this project. Lots of updates since then, but only 3 were directly related to bug fixes, all the others added new functions.
Unless any Gremlins surface, this will probably be the last update for a bit, probably until AOR release a new mode.
Anyone who has the program, or has not updated it for some time really should install v.6.0007-001 when it is posted.
No I have not lost interest. I will still provide 7/7 support. It is just that, especially since the 'Q' additions, and this latest update, the program is about as comprehensive as it can be. It really does raise using the AR-DV1 to previously unimaginable heights.
The 'Trial' is free as always.
Check the web-site for v.6.0007-001. It should be released within a few days.
ardv1
